H/y Pipe Necessary?
If I have a 50 series Flowmaster dual in and dual out muffler, do I need a "H" or X" pipe further upstream? I've read Flowmaster's website and it just refers to the "Delta" flow technology and shows a cut-away of the muffler, not much more info than that...
Did you buy that muffler as an exact fit replacement? If not, what were you trying to accomplish with it? Personally I feel you should balance the exhaust with and H or X pipe, but that would presume you are running duals off the exhaust manifolds and running to "true" duals. Generally, if I remember, a muffler with dual inlets usually mounted up behind the axle, like on Cameros
--Mike
--Mike
Not exact fit, as the factory is dual in but only one outlet. I called around and there's a place that will put a "H" pipe in for $60 so I'm gonna do that tomorrow.
Are you going to have them bend up a second outlet pipe too? To be honest, I don't think I would go through the trouble of the H pipe. If you were running two seperate lines or true dual, then you could use the H to balance the exhaust. Since you are only using one muffler, you pretty much jam it all in there.
--Mike
--Mike
It already has a dual outlet, that's why I was asking about the "H" pipe. But, I already had it done for $60 and about an hour at the local cash-and-no-receipt hillbilly exhaust shop. ;o) I noticed the difference in tone right away but any HP gain sure isn't seat-of-the-pants noticeable--I didn't figure it would be anyway.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,225 Guests (See full list)
