2004 Denali With P0442
welp, i have done some searching around here and found some answers but none that have fixed my CEL for code P0442. I checked all the hoses and everything, didnt see any cracks or holes or leaks. Gas cap is and has been tight. I replaced the purge valve solenoid. i ordered from the dealer, dealer part number 12581282. looks identtical but seemed more loose then the stock purge vavle solenoid. i did have the battery disconnected when i swaped it out. started back up and CEL still on. any other ideas, help,input would be great!!
Just a thought or two:
Go ahead and replace the Gas Cap. the rubber seal may look good on it but oftentimes they will fail and the system will not stay pressurized. Make sure you get a good quality gas cap too! Oftentimes aftermarket locking caps have poor rubber seals. Just a FYI.
Second- Just because the problem may have been fixed does not mean the CEL will go off. That code needs to be cleared out of the computer with the right tool. I learned from a trusted ASE Master Tech that people often think that simply disconnecting and re-connecting the battery or fixing the problem will clear the CEL light but more then not this will not clear the code.
Hope this helps in some way or another!
:lol:
1. - i never recieved a "tighten fuel cap" message on my display, should i still replace anyway. also where and what kind of gas cap should i get?
2. - that is true, i will get the code cleared tomorrow and see if it pops back on
:lol:
What he said, replace the cap anyways. I just did mine and had it cleared at Advance, hasn't come back after a dozen starts now :freak:
    BigJake
    BigJake
  • Who's Online   2 Members, 0 Anonymous, 631 Guests (See full list)
