Dyno
angelic0-
OK, i'm concerned about the gov. limiter ?
How do i run my truck on the dyno ?
what is the closest gear to 1:1 with me having a 4L80E tranny ?
i've got 4.10 gearing but the governor is set at 100mph (160kmh) will it hit the governor before i finish the 1:1 gear ?
I've got 245/75R16 on it now...
Why do you want a 1:1 gear? A 1:1 gear is only necessary on an inertia dyno, if you are doing it on a tuning dyno (ie. load bearing dyno) then a 1:1 doesn't matter.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,179 Guests (See full list)
