How Can I Know If My Truck Has Been Programmed Or Had Tm Removed?
I have a 2002 gmc sierra w/ 5.3, auto,ext bed and ext cab and I can spin the tires pretty easily does this mean that TM has been removed? How would I know if I have a tune/chip installed?
Thanks
Nick
Do you want a tune? :fume:
If you do, you could always send your modules to a tuner such as Black Bear Performance and explain to them your situation.
They'd be able to tell you if you did have one, and if you didn't, you could before they shipped it back! :(
See where the rev limiter shuts down... and you could try to exceed the 98 mph limit. Usually the 2 things most people change. :fume:
But do it in a safe place. :(
I'll watch the rev limiter. I'm not going to try 98mph in a old truck.
2002 old? I don't think so. :lol:
+1
Or you could try testing the TM by accelerating to about 35-40 mph and coast with a closed throttle for a few seconds and then put the pedal on the floor. TM will make a noticeable lag when you hammer it.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 706 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
