2007 Sierra Aux Battery (rpo Tp2)
Good afternoon! I'm ready to install the aux battery in my 2007 Sierra 1500 (new style). Of course the battery tray is there behind the driver side headlight, but beyond that, I have not been able to find what parts I need to hook it all up. I'm going to assume that the relay and isolator are already present, or that they are available as a factory part. I guess I would also need the +/- harnesses and the brace to hold the battery to the tray. I think this is known as "RPO TP2" but I cannot find any specific information about that. Does anyone happen to know what parts I would need to order to properly set this up? My local dealer was not much help :D
I suppose I could get an aftermarket isolator and relay and do it that way, but if the provisions are already there, I would rather keep it stock. Thanks for your help!
Phil
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 393 Guests (See full list)
    • 2013 5.3 still to this day calls for the PF48 filter.  Which as a 15psi bypass pressure.     There is a TSB, 17-NA-157 that talks about the PF-63 and PF-64 filters which have a higher bypass rating of 22psi.    TSB HERE - temp.xml   "Beginning in 2012, the oil pumps began to regulate main gallery feedback instead of pump out pressure. This means that the oil pump now does not begin to regulate until pressure is built up to the main gallery. This change reduces the amount of time it takes to provide oil to the engine bearing and lifters during extreme cold start conditions.  Main gallery feedback oil pump control systems are present on the following engine families which use Spin-on oil filters: Small Gas Engine (SGE), Large Gas Engine (LGE), High Feature (HFV6) Gen2 and Small Block Gen5 gasoline engines. These engines with the main gallery feedback oil pump control systems are factory built with an ACDelco® oil filters"   It also calls out what engines use those filters.  The gen 4 small blocks were not on that list (LMG, LC9, L9H, L92, L94, L20, L96).  Gen 5 small blocks use the higher pressure filter.
    • To me it honestly makes zero difference what filter you run. It's not a race engine, just a truck engine that's mostly bumming highways and it just needs a filter that filters oil.   The filter used to be a 7060 and the long version was a 7045. Now it's the newer updated filter that the K2XX trucks and newer run, the 100255 I believe if we are using napa numbers. Any of those filters is going to do the job.   I wouldn't overthink it, to me it makes no difference because those first filter numbers worked for 18+ years before the spec suddenly changed.
