Rpo Code Different Than Actual Build?
Even notice that the RPO code plate could be different than the actually built truck?
My placard shows rear axle as GT4 and G80.
While changing the rear axle juice, I found this sticker on the left tube:
Broadcast: UK3
Ratio: 4 111
Plant: CBA
Diff: L/S
Model: 605
17-OCT-2002
6683-2
S/N: 65UK3 M22900391
On the rear cover (12 bolts) was stamped:
DANA
52016
26702
Rev-C
080101
I found on the ring gear this number: 4 111.
Bases on the GM service manual I have a 9-3/4" rear end.
Any thoughts ? ? ?
I'm thinking those are just part numbers for the manufacturer of the part. Maybe try spinning a tire and seeing how many rotations it takes to get one full turn of the ring gear to verify?
How long have you owned your truck?
If not since new the PO could have changed the rear end. He may have blown the G80 Eaton locker and replaced it with a limited slip unit that has 4.11 gears.
If since new, I have no idea.
Bought it used about 2 years ago.
PO didn't mention about any "major" repairs.
There was no "obvious" work being done "down there".
The axle date code matches since it is a 2003.
Didn't have the time to do a "count the revs" test.
Hummmmm
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
