93 K1500 4wd Actuator Wiring Harnwess Hookup
I purchased the upgraded actuator and wiring harness from GM for my 93 K1500 pickup but do not know where the extra wire from the new harness goes. Can someone please tell where the extra brown wire goes?
Here's my post from another forum from a few months ago. Too bad you already bought from GM since there are cheaper places out there :lol:.
Also, don't forget to put the spacer in before you thread the new actuator into the housing or it won't be long enough to engage!:
The old thermal design used to wear out quickly and was replaced with a new electric one (you need the actuator and an additional harness). I just replaced the one on my 1994 a few weeks ago. It only took me about 1 1/2 hours, and most of that was spent routing the harness up and over the transmission. Replacing the actuator itself took about 10 minutes. There is also 1 splice you have to make (I made mine in the cab to keep it protected). Make sure you get the electric one. There are still some aftermarket companies selling the thermal one and it will wear out again, plus the electric one engages almost instantly.
Here is Dmaxer's GREAT tutorial:
Actuator Upgrade
Here are the best prices I found when I did mine:
Actuator ($69 shipped)
Harness ($42 shipped)
Thanks for the great explanation and pictures! I however still feel like a failure. I attached the brown wire to the brown wire in the three prong connector coming out of the console but the 4WD did not activate. I will go back and check that the connection was good and try again.
A few things to check (I apologize if these seem too basic!):
1) Make sure they gave you the new electric actuator and not the old thermal one.
2) As I said above, make sure you installed the spacer before the actuator.
No worries, basics are good. I checked that it is the new actuator, verified the plug spacer is installed ans verified the 25 Amp fuse is good. Still no go! Something does not add up, nothing happens! I think I will hookup the old acuator and watch to see if it exends (proof that the switch is working at least). Oh well, maybe there is a lesson in here for me somewhere!
Yeah, good luck. I'm out of ideas now!!
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 817 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
