I Screwed Up...
So I'm starting to change out most/all of the lights to LEDs throughout my vehicle. I was working on the heated seat/ driver 1 or 2 pcb and I accidentally cut some of the PCB...
What I am asking of someone... anyone... what does this part of the PCB actually look like. I can't find the schematic online and I don't wanna buy a new board.
The picture shows my 3 new LEDs that are the heated seat level display LEDs.
I don't have the answer, but I'm wondering what part of the board was "cut" ? Is it that scuffed section between the two left-most LED's that you installed?
I'm checking the post from my phone so it's hard to see on this screen. Sorry. The connections should be similar across the 3 lights. Can you check out how the traces are run on SIP3, and compare to SIP1 and SIP2? I know the traces are cut, but if you have access to a high-power magnifier (15x - 20x?), sometimes you can still see where the wires run, even after damage is done to the board. Holding it up to the light could help also. If you figure out 'what' went 'where'....and are feeling confident, you can start soldering in jumper wires to restore the connections.
Try this...if someone is unable to produce a photo or wiring diagram! Good luck!
Yeah, that scuffed part between the 2 outer most LEDs is what got cut. Im not sure if SIP1 and SIP3 both connected to SIP2 or if part went to the LED.
I will be putting jumper wires but I have to take a good look and hope/pray i connect them correctly.
    Kirk Belch
    Kirk Belch
  • Who's Online   4 Members, 1 Anonymous, 1,178 Guests (See full list)
