Stuff From My Gmt900
alaska511
I have sold quite a bit, I still have:
-GMPP Touring exhaust for CC
-GM stainless step bars for CC
-Centerline wheels and tires.
-GM molded splash guards
PM me with offers, or for info and pics.
Need new toys for my 2500hd!
how much for the splash guards and will the exhaust fit a extended cab
According to GMParts Direct, it is the same for X cab 6' bed as well!
http://www.gmpartsdirect.com/results.cfm?s...number=17801988
The set of 4 flaps $50 delivered.
Cool I will let you know about the flaps by the end of this weekend,how much you want for the exhaust.
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 641 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
