Hard/not Starting When Cold ~25deg F
My 2002 Yukon did not start yesterday. It would turn over and randomly fire but would not start. Later on in the afternoon, I tried it again and it started! It ran rough and smoked (white smoke) for about 45 seconds then ran fine. The smoke was not oil, but did smell like raw gas. No codes/SES light. Started it several times through out the day with no trouble. This morning similar problem, ran rough for about 20 sec and smoked. Once warmed up, runs/starts fine. Still no code.
The fuel pump and filter was replaced about 6 months ago.
Any Ideas?
Thanks!
.... 25F is not all that cold for an engine to start... mine has been starting just fine at -25C every morning this week
... the gas smell was likely left over gas in the system from your first failed attempt to start
... I am thinking that perhaps you may need a tune-up ... if you are near or over 100,000 miles on the original spark plugs, this could lead to the difficulty in starting when colder weather comes....
... maybe a little frost (frozen water) in the gas line when you first tried to start
I should know that "cold" (about +25F) is relative to where you are. Being from Georgia, when it freezes--its cold.
My problem has gone away for now. Still in the 20's early in the mornings, but the yukon is starting normally. I have poured in a can of SeaFoam and toped off the tank with gas from a different station.
Thanks for the responses. If it does it again I think Ill check the fuel pressure regulator.
How white is the smoke...thinking antifreeze=headgaskets
    appletrav
    appletrav
  • Who's Online   3 Members, 0 Anonymous, 344 Guests (See full list)
