Squishy Brakes
grosss
So I'm trying to diagnose a weird brake problem I've been having recently. I have serviced all four wheels (though I think one of the calipers has seen better days), and changed the brake fluid. When I first start driving the truck for the day, or if I haven't really used the brakes much in a while (highway driving) there's a bit of squish to them... kinda soft, and takes some travel to apply them hard... and slamming on the brakes doesn't lock up the wheels. If i'm stopped and I shove my foot all the way to the floor and release, the brakes work great for a good while, nice and responsive, tires will screech.
I'm not sure if it's a booster or master cylinder issue.. or if I should bleed the brakes AGAIN...is this a common issue? (by the way it's the truck pictured in my sig, 99 1500). I've recently driven both 2500 and 3500's and they have incredible brakes compared to mine, but I have a feeling theirs are hydraulic assist instead of vacuum boosted. Is that correct, or are mine just THAT bad?
Thanks for any input.
Stu
    bellssn690
    bellssn690
  • Who's Online   5 Members, 1 Anonymous, 1,102 Guests (See full list)
