How Do I Seafoam Upper Intake On 05 Yukon Denali 6.0?
Hi. I have an 05 yd 6.0 and I want to seafoam the intake. I have the hydra-brake boost on this truck so not sure which hose I can use to distribute the seafoam into the intake evenly. Anyone have a diagram or pic with the hose identified that I need to use to pour the seafoam??
Thanks!
should be able to pull the hose right off the brake boost. start the truck and pull the hose, if there is suction there you should be all set.
The brake booster is a hydroboost set-up. Meaning that it gets it's vacuum from the power steering pump and not the engine.
Yep, you are correct. It does not get the vacuum from the engine. So, any other ideas on how I can get it into the intake evenly distributed?
I found it. Thanks for your help and guidance - really appreciate it!
On the rear of the driver side valve cover there should be a vacuum hose connected to a PCV that sits in the valve cover. You could use that.
seafoam works great, how often are you using it on your truck? I used it on my 4.3L and got excellent gas mileage and it seemed to keep everything clean...
i put it in the oil 100 miles b4 an oil change
i put it in the gas tank a few times a year
i put it in the intake via vacuum
(haven't done it on this truck yet, i now have 6,000 miles is it time?)
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 706 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
