Need Help Picking Out A Cam
I have been researching camshafts a bunch lately, trying to figure out how to read the ratios and what not. I need help with picking out a camshaft. I plan on changing it myself. I already have the whole front of the truck taken apart(do to a wreck.)
I want the muscle car sound, but how big of a cam can I get without changing a bunch of stuff? Someone help me out.
It's a 305 5.0L, TBI, 9.3:1 Compression.
I have a stock engine, other than the air intake and a couple of minor mods. If you need to know any more spec about my truck ask. Also any could cam changing guide onlnie?
Your best bet is to call a cam company and let them know what you want the cam to give you (high end, low end, etc.) and they should suggest a good grind for you.
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
