Service 4wd
Sorry to start another Service 4wd thread.
from reading on here, the message I received is most likely the switch. Pushed all buttons, no response, shut off, restarted and now fully operational.
Could someone post how I remove the switch from the dash panel? I'd like to remove the switch to check for cold solder joints but do not want to break anything.
Thanks for the help.
Jansen
2004 Sierra with 70000 miles, SLE Trim, Autotrac Z71 Ext Cab 5.3
Jansen
Lower tilt column to lowest position. Pull face trim from Dash watch out for the hazard button as they are easily broke off on some models..... It will be either bolted/screwed or held by clips...
Jbo
Jansen...
I replaced the switch just last week on my wife's 04 Yukon with no luck... If you turn the truck off and restart it, it works fine. I'm starting to think it's the encoder motor.
Tom
Jansen
Another quick question: did you hook up a code reader to it to verify?
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 436 Guests (See full list)
