Maf Sensor
I cleaned my MAF with MAF cleaner by CRC. I reinstalled and with in a couple of days check engine light came back on with same codes. (bank 1 and 2 lean)
Is it time to replace or can it be something different. I have also replaced the 4-O2 sensors.
2003 GMC Sierra 4 X 4 5.3L (T)
Thanks!
Both jennabear and davidw have good ideas. My 97 5.7 was doing the same damn thing and it turned out to be my exhaust. Call me crazy but running a true dual with no mufflers was not creating enough back preasure and because of my intake allowing more volume in, and my exhaust allowing more volume out without any change in fuel input, it was causing my truck to run lean. I cleaned and checked and replaced everything. Ran it time and time again on a snap on diognostic computer and watched my truck run from idle to 5280 rpms and nothing. Threw an xpipe in the middle of my pipes and code has went away and truck runs like brand new again. Lean is simple, more air then fuel. Your maf checks out, you have new 02's. may want to have it hooked up to a computer while running and watch what she does and look at the numbers she is producing.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,117 Guests (See full list)
