Electrical Problem
Previous owner of my 1995 Tahoe had a shop work on my door locks etc and I think they screwed up the electric mirrors according to previous owner! Anyway, taking it back to them is not an option and I have started troubleshooting myself and I am stuck ....
I took off the connector to switch, and I have Orange 12v, using a test light (and MM) using external ground. I have power.
Secondly, I test using the light, on Orange 12v AND connector ground, I STILL HAVE LIGHT, but according to my troubleshooting guide, I now have an open "D" wire (says red wire, but I don't have a red), but D is indicated on the connector. Is my switch, switching the voltage or the completing the ground to get motors to run????
Any ideas what I should try next, as I have had the door panels off and reconnected the wire harness connectors in both doors at mirrors and at LH mirror switch????
I would like to know how to wire up 12v and/or ground to mirrors to make sure my motors are good, but not sure what wires to use to do that .... and if there is anything else I should do .....
Hope I explained this all correctly ......
How many leads are there at the connector to the mirror plug (between switch and mirror)? It has been a few years since I did one on my 96 s-10. Are you are getting power at that junction? Are you getting power at the plug junction on the pass side?
--Mike
Mike, There are 6 leads, labeled A thru F ..... yes I have power at the switch connector and I failed to check it at psgr mirror connector, but it has 4 leads at the mirror connector!
--Mike
I would use a test light at the connector where the mirror plugs to the lead. Usually you can use a grounded probe, work one of the mirror directions and see what is hot, if anything. I would venture to say you are supplying power from the switch to the mirror, not a ground source.
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,094 Guests (See full list)
