Cleaning the engine compartment
Torque Junkie
I'm tempted to try this, becuase the local PowerWash has an engine compartment mode.
Has anyone done this before, and if so does it work?
Thanks
-Mike
I know alot of the car detailers around here will steam clean your engine.  For your truck make sure you WD-40 your dist. cap first, and try to keep as much moisture as possible away from it or you'll be pushing it out of the bay while waiting for it to dry out...
I have done this hundreds of times.  When I wash it at the car wash I cover the carb with a rag then put air cleaner back on.  The only thing to be careful of is not to directly spray the dist. cap.  I also try to run the motor as little as possible before washing it as it only needs to be slightly warm to get the grease off thus avoiding getting hit with so much steam if the motor was hot.
Thanks for the tips, guys.  Well, I went and did it.  I put the rag in the carb, and then covered the distributor with a plastic bag.   It worked, but not that well.  I think I need to do it a couple more times to really get a good job done to it.
Unfortunately, it didn't get the caked-on, burnt-on mud off the headers from my most recent mud excursion, and i fear that my headers are permantly brown now :D
-Mike
.........I also try to run the motor as little as possible before washing it as it only needs to be slightly warm to get the grease off thus avoiding getting hit with so much steam if the motor was hot.
Not to mention a cracked head from the temperature differential.....ruined an expensive pressure washer that way once....
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,137 Guests (See full list)
