Billet Grille...
Ok - this site has be all pumped up to do some mods on my truck, but I want to make sure I know what I'm doing.
I'm thinking of this grille for my truck....
http://www.american-truck-auto.com/billet/...do_871297.shtml
When it says 'overlay,' does that mean the old comes out and the new goes in, or do it just lay over the old one?
Any opinions on other good sites to buy these grills from? These are the best looking (to me) that I've found so far.
I figured out the answer to my question about the overlay.
However, what does that do to air flow? Essentially, there would be TWO grilles on the truck
Its not going to hurt your air flow, not enough to matter anyways. And yes, it overlays your current grill .... more like sits in front of it. Surprisingly it has a nice look :thumb:
I went with the Carriage Works Billet Grill. It is their bolt-over version. Excellent quality and fitment. Here's a picture of it installed on my '07 Silverado...
That's great. Thanks. Do you ever have problems with seeing the honeycomb through the bolt-over?
As long as you have the black honeycomb you shouldn't have a problem unless you are close and looking for it. The one thing I like about the Carriage Works one is that the bars are close to each other and the whole thing looks like it was powdercoated black and then just the front edge was stripped and polished. This helps hide the vertical bars that hold it together. I have seen some where its all bare metal and then you end up having vertical lines also which I didn't want.
Here is an image I had to borrow from the net, I'll replace it with one of my own when I get home
Thanks everyone. All the info I was looking for. I have an order of stuff coming in this weekend, and will be putting in another order next week.
Only in certain light, at the right angle. Most of the time, however, you can't even see through to the honeycomb grill!
I like the looks of the Carriage Works on your trucks. Did you get the smooth brushed finish or polished finish? Where is the best place to buy them online?
I got the polished one from a local shop, I've become friends with them and they always match the cheapest online price I find. Try www.stylintrucks.com or www.autoanything.com a couple of sites I use for pricing.
My response would be the same. My local truck accessories guy takes care of me because of all the business I've brought him recently.
Go for it, my suggestion would be to get the lower air dam valence grill too. It completes the look and don't worry about seeing the honeycomb grill behind, unless your looking for it you won't notice it.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 529 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
