You may have had too much coffee when
Jpshostr
* Juan Valdez names his donkey after you.
* You get a speeding ticket even when you're parked.
* You grind your coffee beans in your mouth.
* You sleep with your eyes open.
* You have to watch videos in fast-forward.
* You lick your coffeepot clean.
* Your eyes stay open when you sneeze.
* The nurse needs a scientific calculator to take your pulse.
* You can type sixty words a minute with your feet.
* You can jump-start your car without cables.
* Your only source of nutrition comes from "Sweet & Low."
* You don't sweat, you percolate.
* You've worn out the handle on your favorite coffee mug.
* You go to AA meetings just for the free coffee.
* You've worn the finish off you coffee table.
* The Taster's Choice couple wants to adopt you.
* Starbuck's owns the mortgage on your house.
* You're so wired you pick up FM radio.
* Your life's goal is to "amount to a hill of beans."
* Instant coffee takes too long.
* You want to be cremated just so you can spend eternity in a coffee can.
* You name your cats "Cream" and "Sugar."
* Your lips are permanently stuck in the sipping position.
* Your first-aid kit contains two pints of coffee with an I.V. hookup.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,202 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
