The fat Dad
There was this little boy who woke up 3 nights in a row to hear his parents making noises from their bedroom. On the 3rd morning, the little boy finally asked his mom, "Mom, for the last 3 night I waked up during the night, and I hear you and daddy making noises from your room. Why?" Surprised by the question the mom replies, "Well... I am jumping up and down on him because he is so fat, that it makes him feel thin." Then the boy said, "That won't work mom!" The mom asks, "Why?" The boy then says, "Because after you leave for work every morning, the lady from next door comes by and pumps dad right back up!"
