Cracked Heads
black_bird
Hey guys, new to the site and looking for some advice..
2000 Silverado 1500 Z71 5.3
233,000KMS
I am a victim of the POS "castech" cylinder heads.
First I was adding coolant every month or so, than it was every couple days. No noticeable coolant in the oil. Truck started missing on start-up after sitting for the day (or night).
No visible signs of leaking coolant , ANYWHERE.
Read up and found out the GM TSB for "gradual coolant loss over time with no visible signs of leak", affecting a wide range of 4.8,5.3 engines.
Removed the rocker cover today to find it coated with sludge (caused by antifreze), and a small pool of antifreeze at the rear of engine by valve spring.
SOO,
My question is, what should i do about this??
Replace the heads, and if so, with factory REMAN's (non-castech) ($600 each), or is there aftermarket ones?
Replace the motor with a junk-yard gem?
And while i have the motor torn down that much, should I drop in an aftermarket cam/springs?
Truck is daily driver, has 230,000KM, everything else stock (minus exhaust and intake).
I dont want to dump a crap load of money just trying to figure out the best route to go....
Im stuck here guys and I have to get this fixed ASAP.
Sorry for the rant, let me know your thoughts/opinions.
Much appreciated.
Thanks,
Neil
I`d check prices on aftermarket heads or contact a engine shop and price rebuilt heads, you may also only need one head, I`d check plugs to see if you can determine what cylinder is getting the coolant in it or get a reputable engine shop to check over, 233,000km isn`t alot of km`s for these engines from what I`ve seen, I had a 2000 sierra with a 5.3 that had over 331,000 km`s and still ran like new.
233,000KMS
SOO,
Much appreciated.
Thanks,
Neil
This may give you a place to look before you tear down further
Last year my 1999 gmc 4.8l 250,000 km had all the issues with the valve noisy lifters, loss of coolant with no visible sign of leaks on outside of engine.
I checked to see if I had the castec heads and did not.
Another thing I found in regards determining if you have antifreeze in you oil is your oil will not always be ' milky' on the oil dipstick to confirm that antifreeze has mixed with the oil, antifreeze does not like to mix with oil. You have to drop your oil and if it comes out kind of chunky or blobs, you have antifreeze in the oil, it will end up on the bottom of your drain pan.
I found the problem when I pulled the intake manifold off, THE TOP ROW OF BOLTS ABOVE PUSHROD GALLERIES, (11mm, not the main head bolts) ON THE LEFT HEAD HAD LOST TORQUE and subseqently antifreeze was able enter the oil pan via the valve pushrod galleries, there was evidence of corrosion, etc on the pushrods, aft lifter area.
At this point I was 90% sure I found the leak but decided to change the head gaskets, when they were pulled I found no evidence of leakage around the head gaskets gaskets.
So what I suggest, pull your intake manifold off, (only way to get at the smaller 11mm? bolts) check torque, if loose retorque, put intake back on (new gasket), if not and no sign of corrosion etc in pushrod galleries continue on with changing out head gaskets. If you do this it should take, 2-3 hrs versus 4-8 hr for a head gasket change depending on your experience.
If you are looking for a complicated explanation for this problem there is not one, that was all it is. Let us know what you find, Good luck and pm me if you
  • 1 year later...
Hey guys, new to the site and looking for some advice.. 2000 Silverado 1500 Z71 5.3 233,000KMS I am a victim of the POS "castech" cylinder heads. First I was adding coolant every month or so, than it was every couple days. No noticeable coolant in the oil. Truck started missing on start-up after sitting for the day (or night). No visible signs of leaking coolant , ANYWHERE. Read up and found out the GM TSB for "gradual coolant loss over time with no visible signs of leak", affecting a wide range of 4.8,5.3 engines. Removed the rocker cover today to find it coated with sludge (caused by antifreze), and a small pool of antifreeze at the rear of engine by valve spring. SOO, My question is, what should i do about this?? Replace the heads, and if so, with factory REMAN's (non-castech) ($600 each), or is there aftermarket ones? Replace the motor with a junk-yard gem? And while i have the motor torn down that much, should I drop in an aftermarket cam/springs? Truck is daily driver, has 230,000KM, everything else stock (minus exhaust and intake). I dont want to dump a crap load of money just trying to figure out the best route to go.... Im stuck here guys and I have to get this fixed ASAP. Sorry for the rant, let me know your thoughts/opinions. Much appreciated. Thanks, Neil
This may give you a place to look before you tear down further Last year my 1999 gmc 4.8l 250,000 km had all the issues with the valve noisy lifters, loss of coolant with no visible sign of leaks on outside of engine. I checked to see if I had the castec heads and did not. Another thing I found in regards determining if you have antifreeze in you oil is your oil will not always be ' milky' on the oil dipstick to confirm that antifreeze has mixed with the oil, antifreeze does not like to mix with oil. You have to drop your oil and if it comes out kind of chunky or blobs, you have antifreeze in the oil, it will end up on the bottom of your drain pan. I found the problem when I pulled the intake manifold off, THE TOP ROW OF BOLTS ABOVE PUSHROD GALLERIES, (11mm, not the main head bolts) ON THE LEFT HEAD HAD LOST TORQUE and subseqently antifreeze was able enter the oil pan via the valve pushrod galleries, there was evidence of corrosion, etc on the pushrods, aft lifter area. At this point I was 90% sure I found the leak but decided to change the head gaskets, when they were pulled I found no evidence of leakage around the head gaskets gaskets. So what I suggest, pull your intake manifold off, (only way to get at the smaller 11mm? bolts) check torque, if loose retorque, put intake back on (new gasket), if not and no sign of corrosion etc in pushrod galleries continue on with changing out head gaskets. If you do this it should take, 2-3 hrs versus 4-8 hr for a head gasket change depending on your experience. If you are looking for a complicated explanation for this problem there is not one, that was all it is. Let us know what you find, Good luck and pm me if you
im having the same problem and done almost everything. ill try this and see what happens.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 475 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
