What's In My Truck, 2008 Silverado Lt 1500? Speakers
It's an extended cab. The speaker grills on the back door look like a 4" diameter or something. Did they use anything that small? This has to be the worst stock radio ever.
I have the cd player, non-bose, regular POS radio. Really wish I could make it sound just a little better than a good stock system (so about 3 times better than it is now) for cheap. Was thinking about replacing the rear speakers but man that's little, and maybe adding a small amp. It's the XM radio that's in it now and I'm keeping the head unit.
Been awhile since I upgraded much. If you have a high-line in on the amp can you just hook your existing speaker wires to the amp, and run more speaker wire back to the speaker? Just have to run main power wire and ac on wire? Thanks!
Yup the stock and even the upgraded Bose speakers on GM trucks really suck if your used to better sound quality from another vehicle. GM went the cheap route to save $$$ so you can definitely get better quality from the stock radio if you upgrade the speakers. I blew out the speakers on my old 99 Silverado and 1 or 2 of them on my old 07 Sierra very quickly, and never had the volume up full blast either. The speaker paper tears very easily with too much bass :) Despite having the premium sound system on my 08, the audio still sucks. Heck the audio was better on the stock radio setup on an old Jeep Cherokee i used to have as compared to what I have in my 08! Needless to say, a speaker upgrade is definitely in the works in the coming year or two.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,000 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
