Height Of Lifted Truck
you might want to lift it a little higher to fit 35's on the nnbs.. especially with the 325 width and you might want to regear as well.. but 4" might/should fit 35's.. depends on the wheels/backspacing/etc.
depends what you are currently running, but probably at least 5.5" higher at the fenderwells than you currently have.. so many factors that could change that but that will give you some idea at least.
how i got 5.5" is 4" on suspension plus 1.5" radius on tire, assuming you keep the same wheel and are currently running stock z71 tires.
also.. you don't need to start a new thread for every question :cool:
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 905 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
