2005 Suburban With Error Codes P0300, P0171, & P0131
Have 2005 Suburban 5.3L 52k miles. Runs fine when first started idles around 900-1k RPM smooth. When it warms up idles a little rough 400-600RPM. When the check engine light first came on it ran very rough at idle and a little rough while driving after the short trip turned off and then started again it ran a little rough at idle and a lot better while driving. It is using more gas. Error codes P0300, P0171, & P0131 checked at Auto Zone. Auto Zone sold me an O2 sensor, but thinking more about it the P0300 code has me thinking there is may be a vacuum leak and the leak caused a lean situation for the O2 Sensor to have its issue. Before I install the O2 sensor. I would like to know:
1) What is the best way to go about checking for a vacuum leak ?
2) anyone have diagrams where to check ? Best way to go about it ?
3) any opinions on what the the problem may be?
This is my first post here thanks in advance for any advice
Are you having any difficulty starting the engine initially?
    JustusTX
    JustusTX
  • Who's Online   4 Members, 0 Anonymous, 594 Guests (See full list)
