98 4l60e Vs 2000 4l60e
hey guys, does anyone know if 2wd 4l60e`s are the same between a 98 and a 2000?
Sure aren't...different bolt pattern. Different Torque converter.
And I'm not 100% on this one, but I believe the tail shaft is a 4 bolt, and the 2000+ is a 5 bolt.
thanks, didn`t think they were, guy wanted me to do swapout for him, figured I better make sure they weren`t the same before telling him .
maybe you can help with this as well, I picked up a 2000sle 4x4 1500 for parts for my 01, I know the ecm is different but is the engine the same for the most part, both 5.3`s and is the transmission the same?
Trans is different....it has no tail shaft, it has a T-Case insead.
ECM is the same...engine....everything, Sorry you have a Z71....yeah its pretty much the exact same truck. Everything fits yours.
1999-2002 is the same truck for the most part.
    bellssn690
    bellssn690
  • Who's Online   2 Members, 0 Anonymous, 522 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
