Coolant Temp Sensor
I was told that I need to replace my Coolant Temp Sensor. When I looked the part up online, I noticed that it had two wires leading to the sensor. When I look under my hood, I've only got one wire leading to the sensor. Is it possible I am supposed to have only one wire or am I missing a wire? I also noticed that there are two sensors (one above the other) in the area my coolant temp sensor is supposed to be. Which one is the temp sensor?
where are you looking? .... the CTS is easy to find on the top front of the engine block right beside the thermostat.... on mine it is obvious and there is nothing else nearby to get confused with...
it takes two wires to work... a 5V input and a variable voltage output to your ECM to regulate the fuel flow in the injectors... the connector that pops onto the top of the CTS has a two pin receptor
(there is a different temperature sensor on the drivers side of the block that operates the temperature gauge on the dash)
yes, even on the V6 the CTS should be in the same location ... on the top front of the engine near the thermostat... the one you see near the exhaust manifold only controls the temp guage on your dash and has nothing to do with regulating your ECM
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,011 Guests (See full list)
