Belltech 4" Shackle/hanger Drop Problems ( 1996 Extended Cab)
I am having some reasonably severe problems with my p/n 6503 Belltech kit. When I go to install the rear frame brackets they don't even come close to fitting my truck. My truck is an extended cab 2wd 1/2 ton. My factory cab mount/box mount is in the way of the bracket attaching to the frame of the truck.
Now it's the center tab of the bracket that hits my mounts. This is the passenger side I have pictured. I made this side work by bending the tab and trimming the end of cab mount that sticks up vertically away from the frame.
The drivers side however is much, much worse. The only way to make the brackets line up is to cut the center brace off of the bracket altogether. I am pretty sure that this is not right. I really have my doubts that I have some screwed up factory wreck, and the truck has 29000 original miles on it.
For reference sake these brackets fit my 94 regular cab perfectly. The reg cab has a completely different mounting setup for the box and cab though. Either way Belltech lists only one part number frame hanger regardless of what configuration the truck is. So does ever other vendor I have looked at ( DJM, McGaughy's and so on).
Anyone here with a 4" static rear drop in an 88-98 extended cab 2 wheel drive?
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 504 Guests (See full list)
