Rancho 9000 Vs Bilstein Hd Vs ?
I tow a sizable camper, and have had a few instances where the concrete expansion joints are "just wrong", and I get into a porpoising pattern. The truck and camper get to bouncing in unison, and it can be too much. Fortunately, this is a rare occurance... but it's an issue I'd like to address. It's a harmonics issue, so changing the weight, spring and/or dampening rates (shocks) are the options. Weight is pretty much fixed, and I use a Reese Dual Cam weight distributing hitch system. I'm not real keen on the notion of installing air bags or anything that would unload the WD system, as sway control requires that the bars be "loaded".
Looking at the dampening end of things (shocks), I've read about the Rancho 9000 models that are adjustable from 1 to 9, with 9 being very resistant to motion. That sounds like a pretty good option, but I've never used them. Anyone have input regarding the Rancho vs Bilstein HD vs other brands for high dampening applications? I like the adjustment idea, as I don't need a rock solid ride 99% of the time, but do need something more when towing.
I'm not totally tossing out the idea of air bags or supplemental springs, but those are a shot in the dark for the issue I'm having (they could make it better or worse).
Air bags is the only way to go. Period.
Argue, or overthink it all you want.
I put AirLift air bags, and Bilstein 5100s all the way around on my GMT900 1500 Crew and towed a travel trailer all over Alaska.
You won't regret it, ever.
I've read a number of experiences online by others that have tried air bags for this exact problem, without success... sometimes making the problem worse. Air bags don't always mix well with a WDH system w/ an integrated sway control that requires the tongue weight in order to work right (Reese DC). My previous camper didn't do this, so it's a specific combination of my truck, spring bars, camper and a few concrete roads. My truck doesn't sag (1200 lb bars) or sway now, so I'm unsure how additional support will help... but I'm open to being convinced. Cost isn't the issue, but I don't want to waste time/money either.
I'd be interested to know your full setup. Hitch type, weights, lengths, etc., and whether you tried the Bilsteins before the air bags and whether you had "porpoising" before doing so? I appreciate the input.
I don't know much about the air bags...but as far as the Rancho 9000XLs, I've never had a problem with them. The adjustability is very nice, but once I found the perfect setting on all 4 corners I have not touched them since. Much better ride than stock regardless.
The more I've read on this, the more it sounds like Bilstein HD may be a promising experiment. Most folks have eliminated or significantly reduced "porpoising" on concrete roads with this simple swap. I probably only need the rears, but wonder if it's worth the hassle to do the fronts too... since the stock fronts ride/handle good to me. Maybe do the rears, see how it feels, and then the fronts later? Tires/wheels are stock size, so there's no extra unsprung weight to control, just higher dampening when towing the trailer.
i have bilstein HDs...awsome shock, i'm warning you that the truck will ride a little harsh unloaded, but loaded it rides like a cadillac...lifetime warranty too
Did you put HDs on front and rear? When you say "harsh", like "you'll knock out a tooth" or "rides more like a HD truck"? The stock Z71 suspension isn't exactly smooth to begin with, but maybe a little too much travel for heavy trailering. The "hd trailering pkg" trucks I've driven w/ the monotube shocks feel good to me (I'd call it "compliant" rather than harsh).
i have HDs all the way around the truck, i'd say it rides stiff unloaded..it handles loads alot better since the new shocks, the oem shocks suck ass and was told they only last till about 60k and the average driver dosent even notice they are shot
These statements don't make any sense, really. These people don't know how to set-up a hitch, or get the air pressure in the bags right. There is no downside to bags, unless you set it up wrong. If you don't like the ride, adjust the air pressure. If your WD hitch is set up wrong, it ain't the bags that is the problem.
Valley WD hitch and friction sway on the set up below. Towed perfect, even in strong winds. Don't believe the negatives you read. Just set it up right.
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 501 Guests (See full list)
