1995 C1500 Short Box V8 5sp Manual
1995 Chevy C1500, Short Box 2wd
350 TBI with 5-sp manual transmission
178,000 miles on body, 300 miles on motor
New:
Front brakes (calipers and pads), Rear drums
All brake lines (custom fit stainless)
Fuel Tank, straps, Pump, sending unit, lines, filter
Shocks (all 4)
Rear axle seals / wheel bearings
Seat cover
Radiator / hoses
Exhaust (complete, stainless magnaflow y-pipe / converter)
U-joints
Body:
NO RUST!
Cab corners replaced
Fenders Replaced
POR 15 on door inside bottoms
Motor:
1974 350 block 2-bolt mains, .030" overbore
Speed-Pro hypereutectic Pistons
Speed Pro Engine Kit (federal mogul bearings & rings, fel-pro gaskets, new timing chain, oil pump, etc)
Stock rods, new bolts, re-sized
58cc cast iron heads, new valves / guides / seals / springs
Long slot stamped rockers
Edelbrock performer TBI Cam
Stock TBI injection, custom Harris Performance chip (runs as well as stock)
New Distributor cap / rotor
New Water pump
New plug wires
Transmission:
NV3500, shifts perfect
New Clutch, flywheel, pressure plate
New clutch fork
Truck has new paint, but it's not the greatest – I would call it a 20 foot / 20 MPH job. The truck has Herculiner bedliner on the bottom – looks great and protects from rust / paint chips. Interior is in good shape – has bench seat with new custom fit seat cover. No service lights on of any kind. This would make a great work truck, or a good start or a hot rod. If the later is your style, I also have all the parts to switch the motor over to a Carbed 320 HP. Looking to get $3100 OBO
Call or email Matt @ 585-409-5086, [email protected]
located near Rochester, NY
    scotthvac.net
    scotthvac.net
  • Who's Online   2 Members, 0 Anonymous, 381 Guests (See full list)
