New Member, New Truck, Two Questions
i have purchased a 2007 sierra 4x4, new style. (5.3, 4 speed)
its awesome, i love it, its my first GM product.
ive done a ton of searching, but google is letting me down on both questions:
my first question, i seem to only have 2 backup sensors, the middle two are capped off in both the bumper ( plastic plugs) and on the wiring harness.
is this normal? or did the previous owner do this?
secondly, my abc computer is toast, it ate a rock once upon a time, and water got through the crack in the case and killed it. ( i know, i took it off the pump assembly it was full of water and grit.... which explains why the guy pulled the abs fuse( the pump runs all the time when you put it back in) )
anyway, i know i need to replace that.
the part i need to ask about is when im braking, when im almost stopped, im noticing a slight shudder, and my tach is showing my rpm's bouncing a little bit. ( from 400-500 to about 800-900)
once ive stopped it idles normally.
its throwing no dtc's
ideas?
thanks in advance.
Nick
ideas?
thanks in advance.
Nick
1) those cameras probably dident' come standandard on your truck so they just replaced the camera's with plugs
2) the bounceing of rpms could be the trans downshifting
Nick, welcome. But that looks like three questions. :cool:
BTW. Im not sure of the answers.
you win, its three.
the backup sensors are factory, or at least factory installed, its on my spec sheet as an option ( i went to a dealer and got them to print it out using my vin)
PICS!!!!! want to see the new ride, and i am curious so i want to see that rear bumper
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 905 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
