2003 Silverado 5.3 Engine - Radiator Hoses And Belts Replacement
I decided to change the belts and hoses before we do a long summer drive in a few weeks. At 88000 miles they were definately due. Here is what I did.
Hoses
- Started draining the cooland (drain plug on radiator, hooked a hose up to it and drained it into a bucket)
- While it was draining I pulled the following items for better access
- cover that sits on top of the radiator, the intake tube at the TB only, and the plastic clamps on the top hose
- removed the top hose....very easy, cleaned the two hose clamp points.
- installed new hose, disgarded the factory clamps and used new hose clamps
- removed the lower hose. Had to access the radiator side from under the truck. The thermostat side required a bit more brute force for removal, ended up cutting this end.
- again cleaned both clamp points...the thermostat side had some residue I scraped off with a plastic squeegy
- installed hose...pretty easy, used two new hose clamps and disgarded the factory clamps.
About 2 gallons of coolant came out which is about what I put back in.
Belts
- removed main belt first, very easy access to tensioner
- removed AC belt, not as good access to tensioner but still pretty easy
- installed AC belt, pretty easy
- installed main belt, struggled since it seemed a little snug, and getting the belt on all the pullys correctly was more of a challenge.
I used Goodyear Gatorback belts, and Goodyear hoses (hoses were a very good fit). All parts were purchased online through Amazon. As a bonus I also cleaned the TB with some Seafoam since I had the instake off. The event took about 2hrs. The old AC belt had significant cracking in it. The main belt was in better shape, but it also had a couple of larger cracks with visible dry rotting. THe hoses looked ok but you never know. Glad I did.
    JustusTX
    JustusTX
  • Who's Online   4 Members, 0 Anonymous, 643 Guests (See full list)
