Under Coating
Do not use any hard, tar-based undercoating.  It will trap moisture and promote rust.
I would recommend Waxoyl.  That's what they use in Europe.  You can make your own Waxoyl too (instructions on the web if you do a Google search).
Back in the late 80's I used to spray undercoating on cars, #### that job sucked :)
I live in Michigan and will never have a car undercoated. As Gnat posted, it closes up the factory drain holes and actually traps water. I can't tell you how many 'rustproofed' cars I see with rusted out door skins along the bottom.
I just hit the quarter car wash weekly to spray the salt off of the underside of the rig.
I say save your $$ for other mods  :D
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,117 Guests (See full list)
