Lower Exterior Door Trim Replacement Tsb
What is the TSB number for replacement of the lower exterior painted door trim/body side molding on the lower quarter of the door panel, located just below the GM Silverado/Sierra badge? I brought my truck in and complained and they replaced it with 2010 clear coated trim (vs the single stage junk from the factory that faded heavily and started to peel), but I never got a TSB number. Dealer mentioned their was a TSB. I've got a friend who would like to have his 07 Silverado done at his Chevy dealer.
I didn't think there ever was a TSB on this issue,even though its common on these trucks,I looked in GM-GlobalConnect for one and couldn't find one....I've never seen one and don't think there ever was one.
There is no TSB? My truck is out of warranty and I wasn't even asked to pay a cent for the replacements.
They probably "good-willed" the repair for you.
Keep in mind even if there is/was a TSB it doesn't mean they have to cover it,TSB's are NOT recalls and do not have to be covered if the truck isn't under warranty.
A lot of customers think that just because there is a TSB out for an issue that its covered,and they don't have to pay,NOT true,TSB's help the technician fix/repair a known common issue.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
