Paint Experts?
Ok heres the deal, The clear coat on my pickup is peeling in spots mainly the hood, tops of fenders and a few other misc. spots. The paint under it is still good and looks fine when its wet. I was wondering if there was a way of just sanding the clear down on the pickup fixing a few scratches with the correct color then coming back in with a new clear coat on top instead of repainting the whole truck? Any thoughts?
Thanks B
Thanks B
Just wet sand the hood with a fairly fine paper, then reclear it again, then wet sand it once more with really really fine paper.
Thanks B
Agreed. Wet sanding with fine sand paper shouldn't destroy your basecoat. Make sure you use the right grit sandpaper, I'd say (but this is just a guess) 800 range for the first wet sand, 1000s for the last wet sand. Granted when I repainted my truck I chose the cheap way out, acyrilic enamel (3 coats of Centauri + primer) so clearcoating is still a mystery to me. If you're doing more than 1 coat the sanding is incredibly important. My truck has a lot of orange peel, due to the fact that I needed it on the road quickly and didn't make it smooth enough. Prep is everything.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   3 Members, 0 Anonymous, 894 Guests (See full list)
