Changing Plugs On A '00 Silverado 4.3 V6
I am looking for a clue as to the best way to reach the rear spark plug on the driver's side. Truck has a manual transmission. The plug is hidden by the steering column and I am thinking of putting it on jack stands, removing the left front tire and going in from below. Is there a better way?
"Stand back! I'm going in!"
That's how I've done it on older S-10s. You don't necessarily have to remove the tire to have enough access
...Truck has a manual transmission...
Welcome valveguy.
Don't know how manual transmission impacts accessibility, but I've changed my 4.3's plugs from above without difficulty.
Just take some time to select a socket with the right depth, or an appropriate short extension.
I do mine from the top, also don't forget to change your Dist. Cap and Rotor Button at the same time you change the plugs.
Mine is an 03 but I have the 4.3L and change them from the Top.
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 321 Guests (See full list)
