popping noise when backing up????
I've notice a popping sound when the truck is cold or has been sitting for several hours but I only notice it when put it on reverse. It sounds like it is coming from the rear end area but I'm not for sure. I was wondering if it could be from the abs brakes or from the drive train?  This is on a 2002 ,2500hd  truck with 2100 miles.
We have had our 2500HD for about 5 weeks and also noticed the noise you described.  It occurs when backing up just after the truck has started to move (maybe about 20 feet).  I wondered if the break calipers where stuck and the noise is caused when they break loose.
Guys
Take the truck to your dealer. GM has a TSB for the problem. They have to replace the yoke in the rear end. Covered under warranty
Thanks Man!!!   I have a buddy at work that has the same problem and I'll tell him about it.   :flag:
i had sort of a groan whe backing up which seem to come from the rear suspension but after they turned my diskcs and sanded my calipers the noise is gone. Maybe its the same thing.
well the dealer turned my rear rotors and sanded my pads and said that would fix it. NOT. 1 day later it was back with a veangance. Now it groans even worse than before. Im afraid that if i bring it back they will want to turn the rotor even more and ill be elft with a lot less life in the disc brakes and have to replace them sooner than anticipated.
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 636 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
