2008 Canyon: Help
GMCanyon08
I can't seem to find a radio wiring diagram for this truck. Can someone post it please? I also see the anti-theft wire, what happens if i disconnect it? I have on-star but it's not active. Thanks
2010 GMC Canyon
Circuit Wire Color Location
Constant 12 volts BATTERY BATTERY
Ignition 12 volts WHITE\GREEN IGNITION SWITCH
Starter VIOLET (NOT FOR REMOTE START) STARTER
Dome Light WHITE (-) BCM BLACK 56 PIN CONN, PIN A46*
Driver's Front Door Pin GRAY\BLACK (-) BCM BLACK 56 PIN CONN, PIN A32
Pass Front Door Pin LT GREEN\BLACK (-) BCM BLACK 56 PIN CONN, PIN A38
Driver's Rear Door Pin LT BLUE\BLACK (-) BCM BLACK 56 PIN CONN, PIN A44
Pass Rear Door Pin BLACK\WHITE (-) BCM BLACK 56 PIN CONN, PIN A39
Trunk Pin NA
Parking Lamp BROWN (+) BCM BLACK 56 PIN CONN, PIN A 48
Lock LT BLUE (-) DRIVER KICK
Unlock WHITE (- DOUBLE PULSE) DRIVER KICK
IGNITION DATABUS WHITE\BLUE (R CODE) WHITE\YELLOW (5V REF) IGNITION SWITCH
DOORLOCK DATABUS VIOLET (DATA) OBDII PIN 2
*BCM is in the passenger kick.
Tach Signal NOT PINK ANY FUEL INJECTOR
Ignition #2 NA
Ignition #3 NA
Accessory WHITE\RED IGNITION SWITCH
Accessory #2 SAME AS STARTER #2
Accessory #3 NA
Starter #2 WHITE\BLUE (MUX) IGNITION SWITCH
Neutral Safety NA
Brake Light LT BLUE (+) BRAKE SWITCH
Parking Brake LT BLUE (-) PARKING BRAKE SWITCH
Clutch Pedal DK BLUE (- 180 OHMS) CLUTCH SWITCH
Reverse Light PINK (+) BCM BLACK 56 PIN CONN, PIN A1
Rear Defrost NA
Window Up D\ DK BLUE, P\ DK BLUE, D\ DK BLUE, P\ DK BLUE @ EACH SWITCH
Window Down D/ BROWN, P/ BROWN, D/ BROWN, P/ BROWN
Keysense SAME AS STARTER #2
Trunk Release NA
OEM Horn GREEN (-) HORN SWITCH
Headlights WHITE (-) HEADLIGHT SWITCH
OEM Alarm Arm OEM REMOTE ONLY
OEM Alarm Disarm OEM REMOTE ONLY
Vehicle Speed Sense VIOLET\WHITE ECM GRAY 73 PIN CONN PIN 66*
*ECM is at the right rear corner of engine compartment.
Motor Lock GRAY (5 WIRE) DRIVER KICK
Motor All Unlock TAN (5 WIRE) DRIVER KICK
Motor Driver Unlock
(disarm defeat) TAN (5 WIRE) DRIVER WINDOW SWITCH
OEM Lock Relays -
Radio 12v orange + radio harness
Radio Ground black/white - radio harness
Radio Ignition (Class 2 Serial Data)
Radio Illumination (Class 2 Serial Data)
Factory Amp Turn-on N/A
Power Antenna N/A
Left Front Speaker(+) TAN FRONT DOORS; Size: 6 1/2
Left Front Speaker(-) GRAY FRONT DOORS; Size: 6 1/2
Right Front Speaker(+) LT GREEN FRONT DOORS; Size: 6 1/2
Right Front Speaker(-) DK GREEN FRONT DOORS; Size: 6 1/2
Left Rear Speaker(+) BROWN REAR DOORS; Size: 6 1/2
Left Rear Speaker(-) YELLOW REAR DOORS; Size: 6 1/2
Right Rear Speaker(+) DK BLUE REAR DOORS; Size: 6 1/2
Right Rear Speaker(-) LT BLUE REAR DOORS; Size: 6 1/2
EMERGENCY!
I found a orange/black wire and a bluish wire on a different harness, which goes where? Also I don't know what Class 2 Serial Data is.
Also, I have 2 left over purple wires on stock radio harness but would that be a problem if I just left them out?
I didn't buy a aftermarket harness for the canyon >.<
this is my HU i'm trying to install. http://www.pioneerelectronics.com/StaticFi...nManual0228.pdf
I got every wire hooked up except the Red and Orange/White.
    blueskytruc
    blueskytruc
  • Who's Online   1 Member, 0 Anonymous, 597 Guests (See full list)
