4.3l Dic
I've been doing some reading in the forum and I saw how you can upgrade the DIC in the trucks that do not have the buttons. My question is, will this work with a 4.3L, or is it just for the v8s? Im just curious.
i dont see why it wouldnt work... you still have all the functions a v8 does, it doesnt read motor specs it reads mileage and changes some functions
It works. I have the DIc upgrade in my 4.3 and it works like a charm. The only things it doesnt do is the obvious instant mileage reading or the AFM showing, but it does everything else.
If you read then you should know that all you have to do is pull off your panel and see if the wire is clipped to the plastic. If it is it'll work.
my truck does have that wire and connector that is plugged in to the plastic...so what all would it show in the dash? I just want to get an idea before I go and buy one
I just did it awhile ago to my dash (GMC 1500W/T)
It's a 4 button switch on the panel...
As before install it shows:
Mileage odo
Trans Temp
Trip odo
Oil Life
Engine hours
After install you also get:
-Timer
-Fuel Used
-Distance left in tank (which is pretty accurate too bad it shows low fuel around 70km left)
-Avg Fuel Mileage
-Individual Tire Pressures
-Chime volume control
-English or Metric mesurement (km or miles)
-I think you can check you oil life % while driving after the install (not sure)
and some other things I may have forgot.... :D
I take these from splat10's post and take a look at some of the posts about this (help with questions) in GMT 900 MOD LINK THREAD located....
http://www.gm-trucks.com/forums/index.php?showtopic=116715 <--here
Add-a-DIC-tome
http://www.gm-trucks.com/forums/index.php?showtopic=63291
http://www.gm-trucks.com/forums/index.php?showtopic=113704
Full Panel - 19159438
Switch only - 15947841
To the OP, As Tanked_darren listed. the DIC allows you to view alot of things. truct me it is well work the money to purchase, you can either get it from the dealership for about 100 bux or go through gmpartsdirect.com for around 70ish bux.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,266 Guests (See full list)
