Injector Or Coil Pack
I have a 2002 6.0L and i am getting the code 302 which is the second cylinder misfire, i have replaced the plugs and wires, it only misfires sometimes but it runs like crap all the time, what would most likely be the problem for an intermittent misfire an injector or coil pack?
easy way to test the coil pack is to swap it with one from the other side of the motor and see if the misfire follows the coil pack.
if you can change the spark plugs and wires yourself you can swap coil packs around.
just unplug it and remove them from the bracket. they are all swappable.
ok so i just had my codes run after swapping the coil packs, so that eliminates the coil pack, is it normal for one injector to go? and on the sheet they printed out it says that a vacuum leak could be a problem too but how does a vacuum leak affect just one cylinder and how do i troubleshoot that?
With the Vortech intake, the gasket could be bad on one runner creating a vacuum leak on that cylinder.
If you can get to it you could spray something (wd40 or carb cleaner) whith the engine running to see if the rpm's change. That is a good way to check for intake leaks on small engines. But access is limited to v-8's.
It should be the runner going to the cylinder with the misfire. The "runner" is the intake manifold "tube" that bolts to the head directly above a certain cylinder. The manifold is one piece so the runner is not a seperate part, it is a specific area of the manifold. On a v-8 there are 8 runners.
i would say check the injector. it's not uncommon for a injector to fail. most times it just dirty. i would run a good injector cleaner thru the system before i would do a manifold gasket. JMO.
good lusk
    appletrav
    appletrav
  • Who's Online   0 Members, 1 Anonymous, 450 Guests (See full list)
