2003 gmc  foglights
I have recently purchased a 2003 sierra sl,,, the only problem is it came with a gray air dam and NO foglights,,  since then i have painted the air dam to match the body of the color.. However, i have not been able to get too much help from the dealer  i know gmsells the lights separately for like 189.00 and then they also sell a kit for 105.00 which supposedly includes the lights???   my truck has wires running out for the lights and i have a switch in the dash,, all i have to do is have the computer reset after installing the lights.    If anyone has the part nos. or more info on this foglight addition it would be a help   thanks
Your dealer should be able to get those part numbers, not sure why they can't.  See if you can find one on the lot with the foglights, get teh VIN and give it to the parts guy.  They should be able to run it and tell you what the part number is for the foglights.  I found the part number for my dome light with the buttons and lights for back seat passengers light that.  It was in a crew cab.
Good luck.
You could probably also pull the RPO code off the sticker from a truck in the lot.  Then give it to our favorite GM parts vendor PartsZone (in our preffered vendor section), and I'm sure he'll hook you up for less $$$ than your dealer.
    ar0517
    ar0517
  • Who's Online   1 Member, 0 Anonymous, 709 Guests (See full list)
