Firsts....
Zane
Today i was the first Non-GM affiliated person to ..
1. Ride in the SilveradoSS
2. Have a private photo session of the SS
3. Take numerous digital and 8mm videos of the SS
4. To sit in the drivers seat of the SS
I'll tell ya, its a pretty mean machine! Very nice exhuast note to boot!  I couldn't get too much of a ride impression because of the limited speed, but i can tell that this is one #### of a nice machine.  :thumb:
Pictures and vids on Monday when i get back..  :cheers:
I can't wait to see the pics. I just hope this thing is fast. I saw my SVT Lightning in action today at Dover and that thing was flat out fast. I am not switching to the dark side but I will give where it is due and that truck is due.
    Gkistler
    Gkistler
  • Who's Online   1 Member, 0 Anonymous, 881 Guests (See full list)
