Ipod Touch O/s 4.1 Freezes In 2010 Bose With Usb System.
I have a 2010 Avalanche LTZ with the high end Bose GPS unit with the USB port in the console.
my ipod touch 64gb 3rd Gen seems to freeze on a regular but inconsistant basis.
what I mean is this..
I leave it plugged in and in the console at all times, sometimes when I start the truck it picks up where it left off last time I shut the truck down.
sometimes it shows that the ipod is connected on the Bose system, but nothing will play until I unplug and replug it in.
other times the Bose system gives me a USB Error, and the only fix is to unplug the ipod and reboot it manually (at this point the ipod is frozen, so I have to hold the top lock and center buttons to force a hard restart)
sometimes it doesn't recongize the ipod is connected, but the ipod is charging thru the usb port.
and lastly sometimes I have to turn off the truck, and open the door to kill the RAP system, then restart the truck and it all works. without rebooting the ipod..
it appears to happen more often if I use the remote start than if I key start the truck, and it seems to happen on key starts if there is a short time between truck on and restart, for example, I drop my kid off at school, I always walk her to the playground, it's only about 2 - 3 min then I come back out and restart the truck, ipod freezes... but if it's like 15 min then it doesn't appear to be an issue..
I have restored the ipod back to OEM settings via itunes and reformatted it, thinking it might be the ipod, still happens..
so I tried a Gen 5.5 ipod video, and it does the samething, so this is definatly a problem with the Bose (BTW it never happened in my Chrysler and it doesn't happen in my Camry, both with USB ipod integration radios)
the dealer has no clue, which doesn't surprise me in the least..
oh yeah and I am running Version 6.0C on the Nav (2011 disc came out last month)
anyone else have ipod issues with the BOSE system?
My 2010 silverado ltz with bose, occasionally act like it has lost the I pod. I have to unplug it so the system can recognize the i pod touch. I took it to the dealer and they had no solution for this minor problem. It has only done it about 4 times in 8000 miles.
doing some searching online and it appears this is a problem with the itouch 4.0 or 4.1 O/S...
there are several forums and sources indicating that 4.0 forward has issues with a lot of vehicle OEM systems (though since it came out in 2010 one would think that GM would have written the firmware on the BOSE system to work correctly).
seeing as I don't use any of the 4.0 specific features, as my ipod is for just playing music in the car, I am downgrading it back to 3.1.3 and will try that to see if it stops hanging up..
so I downgraded back to 3.1.3 on my itouch and it is working very well, no freezing or lockups since the downgrade and I have had 9 engine starts and 3 of them were remote start (which seems to be when it happened more often)
I also noticed that the irritating issue with songs starting in the middle is gone.. (on 4.0 if you listened to part of a song then skipped forward, the next time that song played it started where you skipped from, not at the beginning, even if it was weeks later)
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 545 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
