Still No Heat
johnrugg
I have a 2001 GMC Yukon 5.3 manual control HVAC. My heat problems started last year. I used this site for advice. I tried the HVAC reboot by pulling fuses and it worked enough to get me thru last winter. I went to use heat again this year and nothing again. I tried the reboot again this year a few times still no heat. The temp. actuator is moving the blend door but it still blowing in all cold air. The rear heat is working which keeps the kids warm. The hoses to the firewall are hot and the temp gauge is in normal operating range. What else could it be?? Any suggestions?? Freezing in Mass.
I have the same problem with my 2002 Escalade. Heat in the back, freezing in the front. HVAC fuse pull doesn't fix the issue. I think it is the blend motor actuator, because I don't hear a sound when I turn the temperature from cold to hot. Sometimes I hear a struggling motor, but I am not sure if this is the actuator. I found a guide to locate the actuator, http://www.autozone.com/autozone/repairinf...996b43f80370a01 but it isn't that great. Any suggestions?
1) I am sort of positive that the blend door actuator part# 52474810 is broken for me, because I can't get the gear to move when I change different settings on the HVAC. More importantly, If I move the temperature blend door manually, the air in the front cabin stays cold. Any ideas or suggestions why I am not getting hot air upfront?
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 399 Guests (See full list)
