Question About 2011 Sierra Gmc Mirrors
Alright in the market for a new 6.2 2011 SLE and was wondering if I get a truck that doesnt have the turn signal power folding mirrors already from the factory can I put some on? I know I would have to change out the door panels and switches for them but is the harness there for them? Is it just plug and play or is this mod not possible. I figured it could be done but since they changed a few things in the 2011s like these mirrors only being available on the SLTs now didnt know if it was possible.
Not sure about the 2011's but the signals are probably plug and play as on earlier years but im not sure. Even with changing the panels and harnesses there is a bunch more wiring involved from what I have read. In short doable but not pratical! Depends how bad you want them! If you serach the fourm you may be able to find more answeres but not 100% sure
The answer is it depends. There is a longer thread on here recently about a lot of wiring complications to get all the features to work. The signals most likely will work but you need to hand wire stuff for the auto dim and power fold functions.
From reading you either get a black connector (just heat and power) and white (everything auto dim etc). If you plug in your new auto dim signal mirrors into the black you dont get all the features like I mentioned. On earlier gmt900s and some canadian models you could get the dl3 mirrors from the factory in the LT/SLE trim so they had that white connector. Others didnt have it but may have had the white connector so it would be a simple plug and play.
It now appears on 2011 US models you will NOT get a white connector even if you ordered buckets or whatever on an LT/SLE. Only way is to have the All-terrain package on GMC (and that comes with the dl3 mirrors), chevy z71 appearance doesnt cut it (still the standard dl8). I thought the difference between what connector you got might be whether you got the true truck interior (all LTs) or the luxury one with the 4wd switch on the left and the car door handles (LTZ/SLT and maybe that all terrain SLE).
Again if you are in canada it appears you luck out and can order it as an option with most LT/SLE models for just a bit extra.
Hope that made sense.
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 404 Guests (See full list)
