Rough Country 4.25" Combo Kit
Hey all,
I got on rough country's website determined to finally get a 2" leveling kit. However, i noticed they sell a 4.25" combo kit, which looks like they're 3" suspension combined with the 1.25" body lift for $549. But you can buy they're 3" suspension kit for $250 and the 1.25" body kit for $150 separately for total of $400. Am is missing something or is the combo kit more inclusive?? Either way, i think im going to combo for the cheaper amount unless someone sees something significantly different.
Do NOT even think about that piece of shit 3" lift. Trust me. If you want close to 4" of lift, do what I'm doing: CCM 2.5" leveling kit and zone 1.5" body lift. Believe me, stay as far away from that 3" as you can.
Had to post one more time DO NOT GET THE 3" rough county lift. I wasted (and many others on here as well as gmfullsize.com) a lot of money jacking around with it. It rides like shit, and you need the aftermarket UCA's or you will go through axles like crazy. And the UCA's they provide, rub the springs on front. Same issue with everyone that had this lift. If you adjust them where they dint rub, your front end never aligns properly (tires angled in where you are riding on the outside of your tires). Same problems on every install. Some also had problems with ball joints. Trust me. Stay away. It was so bad, they bought mine back. Either go with their 5" that I heard was great, or like what I'm doing:
CCM 2.5" -$75
Zone 1.5" BL - $200
$275 for 4" of lift is the cheapest way and much better than that RC 3" shit.
Nuff said! Thanks for the help. I was thinking the same thing nick, level kit plus the zone 1.5 until i saw that combo on Rough Country. I will stay away. I have a 6" fabtech on my Sierra, but didnt want to go that big on the silvey i bought about a year ago, plus i want to stay with the stock wheels, i really like them. The help is greatly appreciated!
James
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 1,315 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
