Carpet Question On Nnbs
How far up does the carpet go up in your driver's side footwell? The carpet in mine doesn't appear to go all the way up. The top portion of the carpet appears to be curling down towards me as well, and appears to be loose in the area where a dead pedal would normally be (i.e. - if I put my foot there, I feel the carpet push inwards by an inch or two).
*bump*
If some kind person will just open the door of their truck, look at the area behind the pedals, and provide a response, it'd be most appreciated. A simple photo would work well too...
I'm at work but from what I can remember the carpet in my 2008 Silverado goes about half to two thirds the way up. if you push the brake in the carpet goes to around the same level as the top of the pedal (the part where you push with your foot). My carpet also has a bit of a curl to it, I asked one of the service guys about it back when they swapped out my seat covers and he said his 2009 also does it and he just used double sided tape to hold it down. I have to pick up some velcro for my WT floor liners (using the hook side to keep them from moving on the passenger side) so i will probably use a small piece to hold the carpet down also. If you still need a picture I can try and get one for you after work.
Mine was the same way
This is what the dealership did to mine also
it doesn't go much more than what is visible from the driver seat.
mine doesn't curl, but i have Weathertech floor liners, I don't really see much of my carpet
    ballencd
    ballencd
  • Who's Online   0 Members, 0 Anonymous, 484 Guests (See full list)
