Chasing A Ghost Mis On #6
gamc
Ok guy's this is goining to be long but any and all opinions appreciated.
5.3 LM7 in a Z71 04 Sierra
Throwing PO300,scan shows misfires at idle on # 6. clears off idle with or with out load
Swapped out plug,wire coil and injector. Compression 180 at 4 revs, # 2 cylinder 210 at same
Going to pull the valve covers in the am and change valve springs on # 6 and check valve movement
The heads were replaced about 35k miles ago because of the porous casting problem in 04. New heads but they installed the old hardware including valves in the new heads after grinding the same.
I've read the TSB on cam lobe wear and am holding my breath I don't have to go there.
Any and all approaches to the problem will be appreciated
Thanks gamc
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,259 Guests (See full list)
