Anyone Runnign 285/70/17 Toyo Ats?
Hieneken49
I just installed the ( LT285/70/17 load range D ) toyo ats on my truck and a RC 2" kit. I used my superchips cortex programmer to change the tire sze to 32.75, as per the toyo website, and my spedo is still off. it says im driving aprox 3-4mph slower than i actually am, (according to my GPS) anyone have any ideas?
Jake
Not to sound like a smart @$$, but just measure the tires at the pressure you normally run them. If that still doesn't yeild proper results, then either your chip or gps is slightly off or a combination of the 2. If that doesn't work I'd just play with the tire size setting till the gps and speedo match, because my bet would be the gps is right on.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 817 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
