2000 Sierra Heater Issues
I have a quick question and was wondering if anyone could help me out. I have a 2000 sierra and I have had heater issues in the past all of which have been repaired by replacing the blower resistor. So my issue now is that no matter what setting the fan is on, they all blow at top speed, I just tried replacing the resistor yet again and it didn't change the condition at all, and thankfully I still have heat, but in the middle of winter in Ontario I have to drive with the windows down because my truck is like a sauna.
Any suggestions would be greatly appreciated. Thanks ahead of time
Will
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
