Water Pump Parts?
Looking to replace the water pump and thermostat on my 2003 Silverado 1500 (5.3L) but having some difficulty finding exactly what I need. It looks like I need a 251-743 (AC Delco) water pump kit but what I cannot figure out is what items, exactly, this so-called "kit" includes. I started looking for a 251-714 water pump kit but found an AC Delco bulletin somewhere that stated AC Delco part number 251-714 was replaced by 2 part numbers: 251-743 "water pump" and 15-7524 "inlet, thermostat, seal". However, the 251-743 is still listed as a kit in the catalogs I am looking at.
At the end of the day I need the items below - please help with the part numbers (AC Delco)!:
Water Pump
Water Pump Gaskets
Thermostat
Thermostat Seal (does the thermostat have its own seal separate from the water neck seal?)?
Water neck Seal
Thanks!
Usually the a/c delco pump comes as a complete unit.
Ok so I am slow here. What do you mean by "complete unit"?
It sounds like you are saying the 251-743 water pump kit contains all of the items I am asking about (water pump, pump gaskets, thermostat, water neck gasket, thermostat seal) as a kit on that one part number - right?
I just bought:
GM part#19256261 & AC-Delco part#251-743
It comes with the waterpump and gaskets. You need to purchase the the thermostat and thermostat gasket seperately.
